CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
W215 ABC delete, Yellow speed racing coilover DIY installation
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jan 4, 2017 | 08:51 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Originally Posted by pmercury
I can not believe your friend can shut the ABC of without messing with the HEX file. that is something mercedes doesn't do neither a dealer has developer mode DAS like I have.
Untill now, I am not aware of anyone having the whole ABC out of the car and no warning lights. It's all "I heared", "someone said", ect.
Whatsoever, Strutmasters module is arriving in 2 days
then I will try out the module with the whoçle ABC out of the car in DAS ABC mode and switched in DAS to AirMatic mode. I will try combinations with fuses ect
I will post a threat for the whole mess
crossing fingers.
Let me know how the module works. I wish these were as easy to code out as the r230. If it does work I can pull on the trigger for an CL65
Old Jan 5, 2017 | 12:37 PM
pmercury's Avatar
member
CL
Old Jan 5, 2017 | 12:39 PM
pmercury's Avatar
member
CL
and yes the module deletes the lights perfect, everything is gone
they made it easy and added a programmer socket on their board so it's easy to read what's in there
that is something I'll go on with once I finished my CL
tomorrow the struts from yellow
I will do a test with DAS later and see if DAS gives me ABC fault codes or that it even fakes abc to DAS (weird sentence huh ?)
Old Jan 5, 2017 | 12:51 PM
Wow so the Module actually works??? Looks like time to shop around for a CL
Old Jan 5, 2017 | 12:56 PM
pmercury's Avatar
member
CL
yes it works perfect
also, the mainchip with the program is a stupid ordinary ATMEL chip
so really easy to clone
I paid 420$ for the module + 156 shipping to europe + 180$ taxes on arrival
quit expensive for a 20$ thing
Old Jan 6, 2017 | 11:59 AM
RA71025's Avatar
Pmercury,
keep us posted on your install and updates. If you figure out how to manually disable the warning abc completely we will all owe you a major debt.
Old Jan 6, 2017 | 12:08 PM
  #32
Ricardo Jorge's Avatar
cl500 w215
Originally Posted by aarkaah
Pmercury,
of course pmercury.
because I live in Portugal I have to wait and wait and wait and wait..... for the package
Old Jan 7, 2017 | 12:51 PM
  #33
pmercury's Avatar
member
CL
here is my setting, I like it low and fast
Old Jan 7, 2017 | 12:54 PM
  #34
pmercury's Avatar
member
CL
and here is the yellow manual they join in the box. don't have time to make a pdf, but if someone has time.... also, in the manual they say it's not really recommended to mess arount with the spring setting.
Old Jan 8, 2017 | 10:36 AM
  #35
I wonder if these springs can support the weight of a CL65. I know some of the coilover stuff on the SL55 wont have spring suporting the weight on the SL65. Pmercury yours is a CL600 right?
Old Jan 8, 2017 | 11:37 AM
  #36
pmercury's Avatar
member
CL
Mine is a cl600 and this kit is for a cl600
same weight as a CL65
I just have 100 more HP then the CL65 lol
Old Jan 10, 2017 | 02:13 AM
  #37
pmercury's Avatar
member
CL
here is my first result, I will publish my coil presets today as nobody did
don't forget to put grease on the struts and Outside Serrated Cable to avoid the rubber to move up and let dirt in
KLEEMANN CL600 712 Hp
Old Jan 10, 2017 | 02:14 AM
  #38
pmercury's Avatar
member
CL
Old Jan 11, 2017 | 02:44 PM
  #39
cl500 w215
Originally Posted by Ricardo Jorge
of course pmercury.
hello pmercury
today I received my coil overs
can you sell me a "copy box" of the other manufactur that you bought?
Old Jan 11, 2017 | 03:10 PM
  #40
pmercury's Avatar
member
CL
clones will be available soon. I need some time
maybe available in 6 weeks
Old Jan 11, 2017 | 03:12 PM
  #41
cl500 w215
ok
Old Jan 16, 2017 | 07:41 AM
  #42
pmercury's Avatar
member
CL
HERE IS A EMAIL FROM YELLOW:
Hi,
Spring preload should not be changed, you can turn the adjuster knob clockwise to make the damper stiffer.
Kind Regards,
Websales Team
so as I said before, do not touch the spring preload settings not take the springs of the strut if you do not have any tools to set the load weight correctly !
Old Mar 12, 2018 | 11:33 AM
  #43
Puerto Rick's Avatar
2003 CL55 AMG Komp.
Sorry to ask so late. were these ever able to be cloned? i am doing the Ceika struts and need to delete the ABC Warning.
Rick
Old Mar 12, 2018 | 02:39 PM
  #44
pmercury's Avatar
member
CL
Rick
sorry, I is possible, but I didn't went on to do it
Old Mar 12, 2018 | 03:15 PM
  #45
2003 CL55 AMG Komp.
Was there any other option to get rid of the warning without spending $200 at Strutmasters?
Old Mar 12, 2018 | 03:56 PM
  #46
pmercury's Avatar
member
CL
found and posted settings in Xentry Das
never tested, no time
Old Nov 23, 2018 | 08:47 PM
  #47
ctravis595's Avatar
2002 CL500 to CL55 conversion
Great advice on grease application. I’m installing yellow speeds on my w215 next week to replace my SM kit.
Curious what everyones using for settings for the cl55/cl500 models in particular. I ordered 16/16 front and rear spring rates
Old Jan 25, 2019 | 11:38 PM
  #48
ctravis595's Avatar
so yelow speed sent me 20kg/14kg spring rates even though i asked for 16kg front and rear...
i notice you seem to be the only w215 owner with 14/10kg spring rates..do you have the same issue with the bounciness at high speeds?
i complained to yellowspeed and they sent me a pair of 16kg springs, they claimed these springs are "linear spring rates" and that the 20/14kg kit is progressive spring rates?
they both look like linear springs to me... (equidistant coil spacing)
trying to team up with you fellow yellow speed w215 owners to find out the safest springs for yellowspeed kit...besides the bounciness at high speed "wavy" roads and bridges, its a great kit. id love to try different combinations but i have lots of other minor things on my w215 that im restoring right now...just did valve covers, spark plugs, shift bushings, oil, etc and im buying my first house right now. id love to work together instead of waste time
Old May 8, 2020 | 01:59 PM
  #49
Sportunage's Avatar
2005 W215 CL55 AMG
Mine came with 20 front and 16 rear springs. I’m also running both front and rear sway bars. Just left the junkyard to get some suspension hardware. Car should be on the ground today. Hopefully, I can get the height dialed in. Shock threads are greased and the are in the car (tops mounted only). Can’t wait to drive it. Once I have everything dialed in, I’ll be doing some research on preload. I know that the manufacturer says don’t touch it but I know better working in auto manufacturing and being in motor sports for the past 23 years. Hopefully together we can find a solution to this bounciness that I’ve been reading about.
Old May 8, 2020 | 05:25 PM
  #50
ctravis595's Avatar
The bounciness improves when I removed nearly all preload, just enough tension to keep the springs from spinning freely
but still wasn’t perfect
I agree I think together we can find the solution, my best idea so far is yellowspeed front coilovers and strutmasters in the rear WITH upgraded/firmer springs on the rear strutmasters. This is the best of all worlds but unfortunately you’ll need to buy two kits
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
