Unknown engine problem ????
any Idea is welcome
anyone had this before ?
My engine started up, hesitating, then nearly shutting of and after a minute running normally
now when I accelerate the engine follows the pedal but with delay
I didn't try to drive yet, only in 1st gear and reverse
same problem, like no power and long delayed
I just had my ecu reprogrammed also removing abc for coilspring
maybe I disconnected something or it might be electrical
no codes in DAS
weird
not the pedal
I have near to 0Mv on left downstream Lambda
and 1000+mv on right
tomorrow i'll be mesuring the wiring harness and if its not the plugs or harness
then ecu is patially burned as I replaced all Lambda friday
Ill know tomorrow
just the ECU bugged, maybe a bad chip soldering
ecu was reflashed again and the beast worked again
lot's of worries for nothing finally
the beast is awake again !
tuesday I have a specialist adapting two Ferrari 500 v12 mufflers on my cl
i'll post a video for the sound
