CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
'08 CL w/ 90k mi. went on a short drive yesterday, car suddenly running like S#!T
Old Mar 26, 2017 | 05:01 PM
CL63wide's Avatar
CL63
rough idle, CEL, cuts off at idle, hear a soft droney whine like when theres not enough power steering fluid.
First time ever feeling these symptoms.
Any thoughts until I get this diagnosed? Just spent 2700 doing random repairs last week. Yikes.
Old Mar 26, 2017 | 08:23 PM
principledchiro's Avatar
2006 CL55 AMG
What "random repairs" were performed? Sometimes those performing repairs knock a system loose. Don't disconnect battery terminals until the fault codes are pulled; check under the hood for obvious visual faults...loose battery terminals, unplugged modules, unsecured air intake (if has MAF sensor), loose spark and/or plug wire(s) not fully plugged on the spark plug (this happened to me), vacuum hoses and wire plugs off fuel rail pressure sensor, etc. Keep us posted.
Old Mar 27, 2017 | 05:29 AM
AMG 17GT's Avatar
R Nine T
I replaced twice. It's your pulsation damper. Black round and plastic.
Old Mar 27, 2017 | 03:30 PM
CL63wide's Avatar
CL63
So it sounds like two separate issues huh.
Motor mounts, transmission mounts, etc
Old Mar 27, 2017 | 03:34 PM
CL63wide's Avatar
CL63
Ding Ding Ding.....You nailed it.
Another $2k down the money pit to fix both issues. The stalling issue is the crank sensor.
Old Mar 28, 2017 | 08:01 PM
AMG 17GT's Avatar
R Nine T
