Bought a 2004 CL55 AMG!
I found it localy: Car guru listing
Looks and feels just like the pictures do. Normal amount or rock chips. The Passanger door handle has the chrome cracked off and the drivers seat control panel (the wood trim) has come a bit loose off the door pad. Seats look and operate like new.
Things i have noticed that are a bit odd:
The doors take a while for the windows to come down when opening, almost like I feel I am pulling too hard/fast. Then they also take about 5s to go back up after closing the door.
all 3 soft close mechanisms are working, including the up down motor on the trunk with no noises.
radio sounds very strong, but No Sat radio
no weeping on all 4 struts, it goes to my Indi tomorrow for a check up and all fluids changed, negotiated the fluid change and the check into the purchase price. The Indi is going to pull the panels and check the ABC blocks. I up and downed the suspension about 5 times, and i also saw the car parked for about 2H while we did paperwork/waited on my wife to come and let me buy the car
Motor sounded strong, cold start with no abnormal exhaust and quick to turn over.
Drive went well, unfortunately i do not have much to compare it to in power, but it is faster than my E550 that i had previously even though it weighs quite a bit more. The top end is astounding, should be fun.
I hope to learn more! and sorry about the crappy picture, more will come when I have my proper camera.
Looks like it has original tires and wheels. You can make it handle significantly better by going bigger and getting some lowering links. Not that much of an expense and well worth it in my humble opinion.
I saw that add and wondered about the wheels. They are not the factory wheels for the car. That design wasn't offered until a few years later on some 07+ Models.
They don't appear to be 20inch which is what that design commonly is. Are they 19s? Just curious.
In any case, she's a beauty! Looking forward to hearing your ownership impressions in the future. And lowering links would definitely be a great mod.
Ron, your w215 is gorgeous as well!
They are wrapped in a H.Performance Hankook tire. They also have 0 road rash, for 50k miles these may have been put on this car recently. I am not sure if these were available as options when the car was purchased.
I noticed I will need to wrap the rear section of the Quarter/bumper from rocks as the tires are outside the wheel well. (FYI i am not a wheel guy, as long as the car matches and they are safe at speed I am happy)
Overall they look like genuine MB AMG wheels, and IMO were the right choice for the car.
I just noticed also, that my dome light will no longer turn on when doors are opened, yes i checked the switch. When turned to "on" they will illuminate. I have to check on that this weekend.
Also, sometimes the amp for the speakers will go out, causing a "radio not available" on the head unit. I think i need a new SAM unit. But we will see. the radio still works 98% of the time.
Otherwise the car runs like a champ, need to replace the idlers and the inter-cooler pump and she will fly.
