CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Voltage Regulator Symptoms
Old Jun 17, 2017 | 08:25 PM
khutchinson22's Avatar
CL55
i replaced my voltage regulator about 4 months ago and the same thing just happened to me today where all systems shut down, I got all sorts of warning messages and then the display went blank. Is there anything besides the regulator that could cause those same type of symptoms like a voltage regulator going bad? Or did I just end up with a faulty one? The strange thing is that now that I'm stopped everything comes back on and goes back out. Sort of like a faulty wire that's trying to make connection. This leads me to believe it might be wiring related.
Old Jun 18, 2017 | 02:05 PM
CL55
Originally Posted by Plutoe
Apply voltage directly to the starter---then load test---what's not kosher!
I don't quite follow. I'm sure what you're suggesting makes perfect sense but I haven't performed much electrical troubleshooting. Can you maybe explain in further detail?
