CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL65 engine cleaning
Old Jun 26, 2018 | 06:48 PM
xabo's Avatar
'20 S63
Going to clean the engine with a spay on engine cleaner. Any precautions I should take? Maybe cover the alternator? Anything else? Thanks
Old Jun 27, 2018 | 12:18 AM
WikedV12's Avatar
cl65
Well, I've only had my car for about 2 months but I don't know that I would spray this engine with any kind of degreaser. Seems like there are to many expensive parts on this engine that I would not take a change on hosing it down. For me it's actually a joy to clean it by hand. This also helps me inspect everything as I clean. But let us know how it goes if you do proceed. Good luck.
Old Jun 27, 2018 | 04:37 PM
Jaap's Avatar
2006 W221 S500L M273
How do you guys clean the corroded/stained aluminium parts?
Old Jun 27, 2018 | 04:55 PM
pmercury's Avatar
member
CL
there is no way to clean that on engine
you take the parts off, you polish
if you want a clean engine, and you want to spray products, do not use agressive stuff
spray W40 after that, to avoid corrosion
it might smoke a bit for 30 min, but that's ok
