CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Radiator Leak / need advice
Old Sep 19, 2018 | 07:57 PM
snagster123's Avatar
CL63 AMG
Just discovered this leak today. Question is do I get it fixed or just get a new radiator. Also, Are there any threads on radiator removal? How do you get the Hoses off the radiator .. those clips look funky.
Pics of radiator where it's leaking... the black is where its wet...
Old Oct 14, 2018 | 04:32 PM
SmokinCummins's Avatar
I replaced mine last fall. I wish I had taken pictures and shared here. There is almost no information on the Internet. I had to remove all the bolts holding the radiator support in place at the top, then tip it forward. Pull the electric fan out of the car. The hoses are held in by wire spring clips that need the tips pushed down to get them out of their pockets. You may need to push the radiator hose forward on the radiator to help them release.
do yourself a favor and check the water pump, belt and pulleys while the radiator is out.
Old Oct 14, 2018 | 04:37 PM
Here is the link to my thread that had some good advice.
https://mbworld.org/forums/cl55-amg-cl65-amg-cl63-amg-w215-w216/671959-cl65-radiator-removal.html
Old Oct 14, 2018 | 11:29 PM
WikedV12's Avatar
cl65
Yes, this looks like a challenge. I was lucky enough that the prior owner had the radiator changed just prior to my purchase. Maybe get one of the online manuals that the Mercedes techs use. I found a digital version on ebay for $15 that seems pretty good. Good luck.
