CL500 (w216) rear window not going up to the end
i’m having this issue with my rear left window that is not going up completely, it blocks at 3/4 then when i release the button, it goes down around 10 cm, and to take it all up i need to take it up 1 cm by 1 cm. It always blocks in the same place.
Another issue is when i open front door, real window goes down but very little, 1cm gap instead of 3 and it goes up when i close the door so the black rubber is well worn and needs to be replaced, i bought it but need to solve the window issue before and dont know how to replace it, do i need to take out the window or can i do it directly ?
Thanks for your help.
