CL65 leaking a little oil
I ended up wiping everything clean. I almost felt like I was under my Dodge Cummins diesel as it has ALWAYS dripped oil. But that is too be expected with a Cummins....but not a Mercedes.
Best way to check is to lift intercoolers and look down at v of engine and rear of engine at top (between heads). If you see any oil there than that is the culprit. Problem is that this cover cannot be removed without removing cylinder heads (both of them). Sucks. In my opinion, given the condition of mine when I replaced it, I would say this will be a major problem for every single m275 as they age-just a matter of time. Some people can live with the leak so better just leave it alone but for me I had to fix it. Engine has to come out but can be a time to do other items that are needed which is what I did.
my symptoms were same as yours and I traced it finally by seeing oil at top of bell housing. After removing intake manifold it was very clear.
I just hope my dream car does not turn into a nightmare......
