NEW - CL55 2003
new the Zone - recently moved out of the BMW E31 world. Now am enjoying the CL55. i have done most of the usual things that need to be done. new better pulleys, belts, oil filter housing seals, all brakes, will be shortly doing front struts, once i get a xentry system.
working on the front Dynamic seats. from reading around it sounds like i have a line break between my fully functioning pump , as all other systems work, and the front seats, suspecting the trunk, since both seats have same issue.
i wanted to look into each seat first to make sure no broken lines in there.
HOW DO the Seat Backs come OFF?
Thanks,
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
thanks. it has 93000 , with only the basic expected maintenance items to do. i do have a few things to repair at this point. the seat issue as stated, and the rain sensor appears not working, and may be related to the vanity lights not working.
i am also in TX, Dallas area. car was imported and sold in Houston, that's where i got it.
