CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CAR STARING INTERMEDIATELY
Old Feb 22, 2019 | 10:56 PM
manja0501's Avatar
SL500 WALD, CL55 AMG. E320
I have 05 CL55. Will drive car, for awhile. Stop, then when I go to start she won't turn over. Try a few times, nothing. Then try one more time, she starts. The dashboard goes out. I get home try to start at times will start, then not. I charged the battery fully, wouldn't start. Put full charge to start she turned over. Left the charger on for a day, it indicated that the battery was fully charged. Dashboard was still out, I was told disconnect the negative for 20 seconds, and dash lit up again. Now car starting no problem in garage. Can someone help with diagnose on problem. Thanks
Old Feb 25, 2019 | 05:59 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
This is almost certainly a crankshaft position sensor issue, research to see if the symptoms match yours
the sensors are believed to fail often because they are in close proximity with the exhaust pieces , leading to early failure
Old Feb 25, 2019 | 06:17 PM
manja0501's Avatar
Crank sensor was just changed about 8 months ago, unless you think it might have gone bad. Thanks
Old Feb 25, 2019 | 09:23 PM
ctravis595's Avatar
Did you replace with OEM?
may be the camshaft sensors
