CL-63 Clock/Date Issues
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Hi, My clock keeps time but not the correct time and date. I've been in the systems Command to set time and date, but my clock will not adjust. I did the format time-zone and manual version, and will not adjust. Also, when I return there, the date is October 2013.
What do do next?
Thanks.
Juan
What do do next?
Thanks.
Juan
2003 S55, 2010 CL63, 2014 S550 4Matic
HI
had this issue in my 08 cl550.
I reset the control module using easydiag lunch
and the clock started to work normally and keeps up with comand unit time
if you don't have the OBD diag Try disconnecting both batteries (if your car is before 2009 you should have two batteries, 1 in the trunk and one in the engine compartment) for at least 15 minutes.
