CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Just installed lowering links, front end lifts up when driving, lowers when stopped?
Old Jul 23, 2019 | 09:06 PM
AMG__Dom's Avatar
W202 C55 (5.4 swapped C43)
Hey guys just picked up my second CL 55 AMG, decided to put some lowering links on just like I have done on my previous car, install was a breeze as usual, car looks great but now having problems.
Everytime I start driving from a stop the front end of the car automatically starts raising a few inches to the point I am sitting noticeably reverse raked. When I come to a full stop the front end dumps back down a few inches to where it should be sitting. Any ideas whats causing this? ran links on my last CL zero issues, have 4 or 5 buddies running links zero issues as well.... About to put the stock links back in and say screw it
Old Jul 23, 2019 | 11:06 PM
anton28's Avatar
2023 Rover
Something with the computer setting that needs to be reset. I've had a similar thing happen when running links on both of my CL's.
Old Jul 24, 2019 | 11:25 AM
pmercury's Avatar
member
CL
you need to relevel the car with Xentry Das
Old Aug 6, 2019 | 04:00 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We have the rear adjustable toe and camber kits to bring your tire angle back to spec. Shame to throw away good tires when the corner edge wears out so fast. on sale http://ultimatepd.com/2003-2006-w215...nsion-kit.html
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
