CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
2011 CL63 m157 heat exchanger
Old Jun 16, 2020 | 11:31 PM
the_indian_kid's Avatar
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
hey everyone. I just purchased a heat exchanger from DTK, who has me covered if it doesn't fit for whatever reason.
Does anyone know this heat exchanger may fit the 2011 CL63 m157 model? Does the design look like it's able to work? I understand itd fit certain m157 cars like CLS and E class that share same part number for the oem part thatd get replaced with this. But CL seems to be bit different.
also, has anyone gone a different route and perhaps built their own HE for this particular model?
Thanks everyone. Stay safe.
Old Jun 19, 2020 | 07:33 AM
pmercury's Avatar
member
CL
you need a replacement for this original part A2215003403
CORE DIMENSIONS:630x300x18 (mm)
24.8031 x 11.811 x 0.708661
Old Jun 19, 2020 | 02:56 PM
Thank you very much
Old Jun 19, 2020 | 03:01 PM
My other question is, looking at the ports of my DTK heat exchanger and the oem one, seeing how they are slightly different design/location, would that make a difference or not really?
Thanks again
Old Jun 19, 2020 | 04:18 PM
pmercury's Avatar
member
CL
Thanks again
well problem is the connections
if not on the same place you'll need to modify them and/or add hose
I struggled a full size radiator into a CL that had a half sized originally
also you'll have to close the spaces on the side between radiators to get a perfect airflow
Old Jun 23, 2020 | 09:20 PM
Gotchya. Hopefully this works out. Thanks for your help eh.
