CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABS Pump Noise like bearing failure
Old Jul 9, 2021 | 11:01 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
I have a 2013 CL63 with about 30k miles. The ABC pump is right up top and makes a sound like a bad bearing. I have read that this may be an accumulator failure instead.
Any thoughts? I can hear the noise very clearly through a screwdriver placed to the pump housing.
Thanks.
Old Jul 10, 2021 | 08:02 AM
Renntech6509's Avatar
2014 ML350
Check the pulsation dampener that's mounted on top of the pump itself. Can create a noise that sounds like a bad pump. That's most likely the issue.
Old Jul 10, 2021 | 03:09 PM
I replaced the damper. It did quiet the noise. I was a simple fix, lift the car off the tires, clean the area, 17mm wrench to remove. I filled the new damper with a thimble full of oil until it was full and installed. Checked for leaks after start, cycled the suspension just raising and lowering a few times, checked the level and was off for the best part; the test drive.
