A/C problem please help!
I am having a problem with my climate control only blowing just mild to hot air all the time, usually whatever temp it is outside the vents will blow. The “AC off” button is not illuminated since that’s usually a dead giveaway something is wrong with the system. I’ve looked over everything from checking the compressor to see if the clutch is engaging to using the hidden menu inside the climate screen and clearing any codes. Also looks like there is Freon in the system, ac has worked just fine and when checking the valve stems there’s definitely stuff in there. I had a A1000 code but as far as I’ve read it’s harmless and can just be cleared with no problems. Could my control panel be faulty and not properly controlling the climate? That’s all I can think of.. Any help is appreciated please!!!!
biker349 (07-21-2021)
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
First thing I think of is to have gauges put on it and see what the pressures are. Modern AC systems seem to sensitive to the quantity of refrigerant (too much as bad as too little). It is what I would do.
