CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Auxiliary water pump CL65 AMG
Old Aug 10, 2022 | 10:25 AM
TomGlo's Avatar
Mercedes-Benz CL65 AMG c216
Hi. Will someone tell me when the auxiliary water pump turns on?
Old Aug 11, 2022 | 06:52 AM
Renntech6509's Avatar
2014 ML350
I believe once the iat reaches 90 degrees.
Old Aug 12, 2022 | 11:14 PM
Harebear's Avatar
2020 G63
You can just jump the relay for it to test it, works even when the engine isn't running
Old Aug 13, 2022 | 03:35 AM
TomGlo's Avatar
the pump works. I connected it directly to the battery. but when the engine is on and warm, the pump does not work.
Old Aug 13, 2022 | 04:10 AM
Harebear's Avatar
2020 G63
Then it's gonna be a bad fuse or relay hopefully, cheap fix
