CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL65 engine oil capacity ?
Old Sep 3, 2022 | 02:11 PM
427shark's Avatar
05 SL65, 05 CL65, & 08 CLK63
So just finished performing an oil change on our new 2005 CL65 amg and am alittle confused about the oil capacity. The owners manual has listed both 9.5 & 11 quarts with filter? I'm assuming this has to do with an optional oil cooler? How could I tell if I have the oil cooler and the correct amount of oil to put in? Our SL65 is pretty straight forward and the owners manual only has one capacity listed. Thanks . . .. also about 10qts came out.
Old Sep 4, 2022 | 07:30 AM
427shark's Avatar
Bueller. . Bueller . . ..anyone?
Old Sep 4, 2022 | 01:16 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
cl65 engine oil capacity - Search (bing.com)
Old Sep 5, 2022 | 03:00 PM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
I have a CL 63 and the procedure shows two different capacities depending on whether you changed the oil cooler on not. A standard oil change would not empty the cooler, therefore the smaller fill amount. I usually put a bit less than stated and then check. Good luck.
