CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
M275 V12 ignition coil cover
Old Sep 29, 2022 | 12:39 PM
TomGlo's Avatar
Mercedes-Benz CL65 AMG c216
Hi. Anyone knows how to remove the ignition coil cover?
Old Sep 30, 2022 | 08:56 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
Do those black tabs hold it on? Just guessing, no experience with these engines.
Old Sep 30, 2022 | 09:32 AM
TomGlo's Avatar
Yes, but mostly it is attached with some strong glue.
Old Oct 4, 2022 | 01:48 PM
Heat? Trying to think if it was mine what would I do? Obviously there will be a risk of breaking the plastic but my guess is you are trying to access the electronics to try and fix the system. Other than the cosmetic issue, if the part is broken then breaking it more (?) might at least get your running while you ran down a replacement/solution.
Good luck with you project.
