CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL63 2008 fuel trim
Old Apr 20, 2023 | 02:47 PM
moaaz's Avatar
CL63 2008
CL63 2008 fuel trim
Hi everyone,
My 2008 CL63 118 KM had an issue with rich fuel on both bank 1 and 2 and another issues, after replacing the MAF, fuel pump, fuel filter, and injectors the problem is solved and no more CEL
my question is now when reading the fuel trim there is difference between bank 1 and bank 2 LTFT
bank 2 always reading -6 to -9 I know this mean it is richer than bank 1
tried swapping post cat sensor
checked all the vacuum lines although it is not possible to be the issue but checked that any way
What could be the issue, please if any one can help that would be appreciated
thanks
Old May 19, 2023 | 08:31 AM
INEEDIT's Avatar
CLK430
Originally Posted by moaaz
Hi everyone,
thanks
Bump
Old May 19, 2023 | 12:34 PM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
Does it run poorly? So many things could affect this but I would check oxygen sensor readings just as an initial thought. Good luck
Old May 29, 2023 | 07:44 AM
moaaz's Avatar
CL63 2008
it runs fine, will check them
thanks
