Retrtofitlabs
If there are other options or if someone has a better idea on how to improve the lighting I am open to suggestions.
Indeed getting the light assemblies out and apart seems by far the biggest part of this job.
I continued to research and found that the new Morimoto Mini D2S projector seems to be the king projectors at the moment. I've been in contact with retrofit labs and they are a bit limited on their knowledge of the C215 and they are using the older E46 projectors. I figure if I have to go through all the work anyway might as well get the best and brightest. I will measure the mounting spaces of the stock projectors and compare that with the Mini D2S to make sure they will fit before going ahead. I spoke to a tech a Morimoto, they do have an adapter plate but it is universal and he could not provide the measurements.
The Morimotos are a nice quality part, but the mounts are not as "deep" as the stock Bosch units. This means cutting a lot of material to get them flushed up to where they need to be. All in all I think it was worth it. The old lenses were "burned" and not shiny anymore, light pattern was not good. Now its nice and crisp. Still a bit of tweaking but very close. The pics don't do it justice, and the parking lot where I too these pics has a bit of a L to R slope so it looks a bit off from how it sits when level (this isn't where I set the beams, long story).
Total cost was about $375 CAD.
Morimoto High beam
Morimoto Low beam
Stock High beam
Stock Low beam
