Transmission Fluid Replacement
Scotty
2012 CL63 AMG Coupe
w/ P30 Performance package
Do you recall how much fluid it required??
Scotty
2012 CL63 AMG Coupe
The refill process is thru the pan on the CL63 (there is no trans dipstick) , if there is I personally have not been able to find one on this 722.9 transmission. once you drain the pan, and put back on , you need to fill thru the pan - put in about 4-5L. Start the vehicle let the transmission get up to temp and then try to put another 0.5 - 1 L into pan. I've heard that the torque converter will hold around 2L of fluid. There is a way to also drain this as well. there is a window in bottom transmission have to spin engine around to find the drain plug on the converter.
Might want to ask who you get quote from if they drain the converter as well. Oh one other thing if its 2012 or newer you need the ATF Blue ( MBZ 236.15) - not the ATF Red that was 2011 and older.
Hope this helped.
-Garry
