CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 215 Rear Bolt on axle ABS Rings
Old Sep 9, 2024 | 07:28 PM
matinnin's Avatar
CL55 AMG
Exclamation CL55 215 Rear Bolt on axle ABS Rings
Hi,
i am having a real hard time rebuilding my axles. i am working with some cores i bought so i can have them ready to swap when i get to rebuilding my rear suspension. i have found the boots with no problem, BUT getting the metal cover off the wheel side joint is not possible and still reuse it. i have in the past just wash these types of joints out with petrol, and regreased , but i want to disassemble and do it right so i can powder coat the axles.
there is a place in Colorado that can press them on, but i wanted to do this myself, and they want 400 to rebuild. not sure if i can find someone local to Dallas to do this.
My main issue right now is that i want to replace the ABS Reluctor ring that is pressed onto the end of the wheel side joint, but i cannot find a part number , or any reference to it. i see lots of them for sale , and a w220 will likely be correct if its the Bolt on type axle. All i know is that these rings are 92mm ID , 96mm OD 10mm wide. these likely will work, but i was hoping to make them as new as possible.
appreciate any info on this job
thanks,
