Any guides on replacing the coolant reservoir? 05 CL55
also, I'm looking to install the VRP split cooling system and looks like the kit comes with a pump but where would I install this pump? and do I need to replace the pump that's currently there? the reason I ask is the car came with coilovers when I purchased it and I remember reading online that you have to change some sort of pump in order to replace the coilovers but I may be wrong. if someone can provide some clarification I would appreciate it. I'm looking to install the VRP kit for split cooling thank you
