Front brakes pulsing under acceleration
Front brakes pulsing while accelerating, straight line or turning. Wheelspin or no, anything above about 1/3 throttle input.
No lights or warnings, no reduced engine power. Seems like only the front. More throttle input the harder the pulsing.
Not speed related, does it from a dead stop or rolling.
The sound is like when the ABS is activated. not subtle like the dsc.
No codes related to the abc, esp, dsc, bas, abs etc.
Thoughts ?
Thoughts ?
Will try driving in dyno mode when I have the chance.
Might see what shops charge for diagnosis and take the $150-$250 dive to have them find the issue for you.
This vibration is not speed related as in it doesn't matter if the car is even moving ( hard launch with wheelspin creates the same problem as going 30 mph with 50% throttle applied) and there is no problem under braking at any speed. Only happens under mid to heavy throttle application (25% or more).
Can't imagine what system is still at work when all the electronic aids are disabled.
