CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How do I remove this interior trim?
Old Dec 7, 2025 | 08:59 PM
anton28's Avatar
2023 Rover
Hey guys, what do you call this trim? How do I remove it?
Old Dec 8, 2025 | 05:00 AM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
first pull off the rubber door gasket that your finger is touching. No need to remove the whole thing, just remove the section that is on the A pillar. Once you remove it, you will see that there are metal clips that need to be slid off of the frame of the car. If I remember correctly, there’s three or four clips on each side. I found the easiest way to figure out how to remove new trim is to go to eBay and find the part and look at the back of it to see the connection points.
Old Dec 8, 2025 | 10:52 AM
anton28's Avatar
2023 Rover
The rubber door gasket is what I'm actually trying to remove. Does it just pop off if I pull on it?
Old Dec 8, 2025 | 10:56 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Yes, it just pulls down.
