New car. Wheel bearing is gone already?
I'm having issus with the front left wheel area. When driving at 120 kmph which is around 80mph, it makes a low rumbling noise that vibrates the footwell area. It happens when going straight or zigzag. It's on and off as well. It will groan for 10 seconds and let off for like 5 seconds and start to groan again. It doesn't matter if the surface is smooth or bumpy either. At first I thought it was a original summer tires, but now I have winter tires on new rims and it still does it. It has happened since day 1, but it's finally getting on my nerves now that I know it's not the tires. What can it be? Wheel bearing? Suspension? Alignment?
Thanks!
This being low can make a similar noise.
Besides that back to dealer.
Once you know the fix do post back, it helps others..
If lug nut torque is as specified my guess is a failing wheel hub bearing. As posted above you need to have the hub replaced before it fails completely and you find yourself immobile on the shoulder.
