Hello,
I'm trying to change the spark plugs by myself
does anyone have a video or how to. With pics
Please help and also can someone tell me which cylinder is number 4 because i need to change the ignition coil for it
i have gal 45 and i just unscrew whatever needed and replaced plugs straight forward job, the rubber boots cover the plugs a little tight so you ll need to pull harder.
but very important is the use air gun to blow out all the derbies collected around inside the plugs. so before you about to unscrew the plugs out blow all that stuff out that way nothing will snick in side of the cylinders.
or may be use those compress air cans to clean your electronics .
c
c
c
Thank you for the important informations i will try to do it todayOriginally Posted by caug
i have gal 45 and i just unscrew whatever needed and replaced plugs straight forward job, the rubber boots cover the plugs a little tight so you ll need to pull harder.but very important is the use air gun to blow out all the derbies collected around inside the plugs. so before you about to unscrew the plugs out blow all that stuff out that way nothing will snick in side of the cylinders.
c
