CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
2014 Front Brake DIY Help!? :)
Old Jan 30, 2020 | 06:37 PM
imbrandonl83's Avatar
2014 CLA45 AMG
Exclamation 2014 Front Brake DIY Help!? :)
Hey everyone,
I'm new here as a member but have been following for a few years now.
I finally decided after my dealership wanted to charge me an arm and a leg on a brake job to attempt it myself.
I did search this forum but haven't found any specifics that I need to do the front brakes myself and would greatly appreciate some help.
I have ordered my front rotors, brake pads, and brake sensor wires, but need help for the sockets needed to remove the wheel, brake caliper and rotors.
I thought I seen on a thread for a CLA250 a gentleman had mentioned using a some specific sizes specifically
  • 18mm open-ended wrench
  • 14mm socket
  • 13mm socket
  • 8mm box wrench
  • T-30 torx driver
I didn't know if this would also work on my 2014 CLA45 AMG? Also the torque specs for for the rotor screw, the caliper bolts, and the lugs on the wheel.
I would appreciate some help very much!
PS... I have also watched the Youtube videos mentioned on other threads. I just need the tool specs for my particular car.
Old Jan 31, 2020 | 06:20 PM
2014 CLA45 AMG
Can someone help????? Jesus 34 views and noone says a thing...
Old Feb 1, 2020 | 11:53 AM
LGAFF's Avatar
2011 E550 Coupe, 1992 Corvette ZR-1, 1991 368ci ZR-1, 1990 ZR-1, 1987 Callaway TT, 05 SL600, CLA45
As someone who does all their own work my advice would be to dig in and do it(runs to store/harbor freight for any items needed).... if you have a good set of metric sockets and E Torx and Torx sockets should be good.... I would disconnect the battery and make sure you review the process. Its not rocket science on these …. I am getting ready to convert my E550 to C63 6 pistons
Where are you located?
Old Feb 1, 2020 | 11:58 AM
LGAFF's Avatar
Actually if you google A45 BRake Upgrade there is a youtube
