Turbo Blanket, any experience?
I bought a turbo blanket supposedly fitting our turbo size. A good quality one (Real LAVA ROCK) is not so cheap.
It supposedly does a good job (read two different studies) in both extending the torque curve to the lower end (my goal), and also adding -very few- ponies. I Already have a stage 2 setup as far as for the ponies.
The fact is that between the tin heat shield between the block and the turbo, and the thick rod from the wastegate, there is no room to put it. I mean, it´s not an installation issue; rather it´s a no room issue so as to lay it.
Is there any trick or idea anyone could contribute with?
Thanks.
Any experience with it you could share?
THANKS!
The one that is being sold specially for this car, is almost the same concept as the metallic OEM shield; it does not fit tight around the turbo as a sock, as it should be in order to prevent the heat from being radiated, but rather it sits in the top of if, at a few mm above, so it does not block heat from being irradiated from the turbo; it mainly keeps this heat from being felt from above.
The "wrap around" blanket does this, wraps an important part of the second turbine (exhaust) so as to prevent heat from being irradiated, and thus keeping the heat inside it in the most part. And yes, it is a PITA to install because of the tin heat shield that´s between engine´s block and the turbo and the lack of space to maneuver.
With some 1 hour fiddling, a few scars in my hands and arms, and of course some curses said, I managed to put it in place.
I WAS NOT ABLE TO PUT THE SPRINGS THOUG, but it sits so fit that it can hardly move. I managed to put it some half inch away from the blow off valve´s stem.
I include some pics for you to see how it fitted.
This way I have all the benefits of a real turbo blanket.
Anyway I was able to put in place the original heat shield, just so as to allow my car to pass the MOT, which is rejected in Chile if there is any mod at sight (and it also helps to keep it in place)
Hope this helps.
Thanks.
