CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
C118 CLA45 Shake, Rattle and Roll, what a mess
Old Jun 6, 2024 | 07:58 PM
jdemusic's Avatar
CLA45
New Owner here:
I am SHOCKED how much this car rattles, Ive owner BMW, Lexus and Infiniti. My GF owns a 2020 250. NO issues.
My car - is a rattle trap, and it's kinda embarrassing. I took it to the dealer last week, and lo and behold after a few days of no noticeable noise its back fierce. I dont know what the source of the noise is but sounds like it's lon the right hand side.
Also unrelated, it's a very uncomfortable ride, but im ok with that. "OH ITS JUST A CLA, ITS SUPPOSED TO DO THAT"
Since the dealer cant fix it - is this something a stereo shop or body shop can help with? I'm in bay area CA.
Appreciate any help!
Old Jun 7, 2024 | 07:59 AM
W205C43PFL's Avatar
Originally Posted by jdemusic
New Owner here:
Try going from checking tire pressures, replacing tires (unlikely the CLA 45 has run-flats but I am not sure), dropping wheel size & tire size, etc.
Does the vehicle come equipped with Ride Control?
Old Jun 9, 2024 | 12:47 AM
Sockinatoaster's Avatar
2023 AMG GT 53
The rattles and squeaks are part of "yeah well it's a CLA." I never have music turned off so I lived with it by drowning it out. But the ride, it's super harsh. The AMG performance seats don't make it any better. I think it's the suspension more than the wheel/tire setup. I have 21"s on my GT 53 and it's a way smoother ride. In my CLA 45 it didn't matter what setting I had the suspension on, every bump in the road broke a tooth. The car rides really low too which may play a part. I work on an Air Force base and there's certain gates I can't use because the spike strips and speed bump hit the subframe.
Old Jun 10, 2024 | 11:43 PM
jdemusic's Avatar
CLA45
Is there a setting in the suspension mode besides comfort that will perhaps help (im on comfort)? I suspect the stiff suspension is partly to blame.
Old Jun 11, 2024 | 09:07 AM
W205C43PFL's Avatar
Does the vehicle come equipped with the Ride Control option and does it come with run-flats?
It is true the 45 will be much stiffer than a 250 though but Ride Control helps, not having run-flats also helps.
Old Jun 11, 2024 | 04:59 PM
jdemusic's Avatar
CLA45
yes- I have both.
Old Jun 11, 2024 | 05:43 PM
W205C43PFL's Avatar
yes- I have both.
Is the run-flats a must or you willing to go Pilot Sport 4S without run-flats with the good ol compressor and fix-a-flat, tire plug or Tirefit MB calls it.
Getting rid of run-flats certainly will help.
Having Ride Control with the adaptive dampers should had helped as well though since you said you have that.
