CLA 45 AMG (C117) 2013 to 2018
CLA45 AMG Tuning Special Offer - Rebellion Automotive
Old 07-12-2014, 06:01 PM
ajmckay's Avatar
2014 CLA 45 AMG
Just ordered from Rebellion!!! Psyched can't wait, will let you guys know...
Old 07-22-2014, 09:38 AM
ajmckay's Avatar
2014 CLA 45 AMG
Rebellion stage one arrived!!
Well when I got home yesterday I saw a package on the porch. The first thing I noticed was that the package was torn and I cringed. The box appeared intact and contained a wire harness (plug and play) and a Rebellion "black box" and a couple black plastic zip ties. I was surprised to find no directions in the package. I was not sure if someone tampered with the box or it was an oversight, either way no instruction. This means I have no idea how to install.
I e-mailed Matt at Rebellion, and to his credit he responded quickly and provided a link to instructions. I am pretty good with cars, but I will say I had a hard time with this initially, as you guys know what an AMG engine looks like. I did figure it out and got the system installed. The directions to not say what to do with the actual Rebellion box or how to secure it or to what. I also do not know exactly how to disconnect the system when I bring the car for service. Do I just unplug the Rebellion box and cap it? Or do I disconnect the entire system, which will be a major pain? I have not driven car yet and I will update on the performance. I will say that Rebellion Automotive (Matt) has been great thus far and has always answered me via e-mail.
Old 07-22-2014, 09:41 AM
ajmckay's Avatar
2014 CLA 45 AMG
Rebellion Tune Stage 1 package
CLA45 AMG Tuning Special Offer - Rebellion Automotive-photo-1.jpgClick image for larger version
Old 07-22-2014, 01:20 PM
VFORCE09's Avatar
2020 CLA 45,2018 C63 Coupe,2016 C43,2014 CLA45,2013 C350 Coupe,
ajmckay all you need to do when take your car for service is unplug the wiring to the box and connect the connector thats provided to the harness and this will put the car back to stock, now as to where to hide the box i used the space between the battery and the computer,,
Old 07-22-2014, 02:25 PM
ajmckay's Avatar
2014 CLA 45 AMG
Thanks Force, Rebellion suggested removing the entire system? Seems excessive, and a lot of work. I will definitely unplug the black box however. I don't know what the dealer would say if anything and I don't want to get jammed up. I put the box on top of the battery box and used Velcro. It is seen immediately, maybe I will move it.
How do you like the tune? Are you happy with it?
Old 07-22-2014, 07:54 PM
bigantne1968's Avatar
CLA 45 AMG
i just take the hole thing out it just takes 5mins to do
Old 07-23-2014, 08:11 AM
  #32
VFORCE09's Avatar
I'm very happy with the Rebellion ECU tune together with the TCU gearbox tune, the car performed a hole lot better than stock, also if I was you I would hide the box so it won't be on plain sight..
Old 07-28-2014, 07:47 PM
  #33
eason's Avatar
W212 E63
What setting are you a guys running with? I am experience some knocking with Canadian 94 octane (which is somewhat worst than CA 91 according to GT-R guys). With gas on 3rd/4th gear at low speed, I will start to hear some knocking around 3-3.5k rpm when I keep stepping down.. I am currently running setting "4" even Matt told me "5" should be good for 95RON/91 octane. Anyone of you here experience that? Thanks
Old 07-29-2014, 08:54 AM
  #34
ajmckay's Avatar
2014 CLA 45 AMG
Tuner Setting
Eason, the unit I have does not have a setting. I have the plug & play stage 1 system from Rebellion. Do you have a different unit ?
Old 07-29-2014, 02:43 PM
  #35
eason's Avatar
W212 E63
I have Stage 1 V2.. there is an adjusting knob if you unscrew the bottom plate.
Old 07-29-2014, 06:10 PM
  #36
bmoney12's Avatar
2019 Audi TT RS, 2020 BMW X3M Competition
I guess I need to crack mine open to see what mine is set to by default. I'm running 93 octane.
Old 07-30-2014, 03:16 AM
  #37
VFORCE09's Avatar
I spoke to Matt yesterday and he said that the stock setting is 6 using 93 octane..
Old 07-30-2014, 05:31 AM
  #38
eason's Avatar
W212 E63
After many tries, I am now settle with Setting 3. No more knocking at any rpm now.
Old 07-30-2014, 02:34 PM
  #39
eason's Avatar
W212 E63
A little bit off topic, but does anyone of you guys with tune box have "Pre Safe Fucntions Limited" warning? I have this pops up avg once a week with the tuning box and car was fine without it. When this warning comes up, the car will cut power and it will go away once I restart the car. It might not be Rebellion as this happened to Renntech box as well.
Old 07-30-2014, 08:58 PM
  #40
VFORCE09's Avatar
Eason I have never had any warning messages from the car with the Rebellion tune and its been installed since May
now are you sure that you followed the instructions on how to install the tune box and if you did then send Matt a private message about your issue..
Old 07-31-2014, 06:08 AM
  #41
bmoney12's Avatar
Originally Posted by VFORCE09
Eason I have never had any warning messages from the car with the Rebellion tune and its been installed since May now are you sure that you followed the instructions on how to install the tune box and if you did then send Matt a private message about your issue..
I have not had that message either and have put on over 6000 miles with my rebellion tune.
Old 08-01-2014, 02:20 AM
  #42
kuba.95's Avatar
Mercedes-AMG C63S Edition 1
My car had the same issue (It's Superjak95). Probably will need to go to the dealership for this since something might be broken such as the ESP control unit, Traction Hydraulic Unit etc which were the parts which broke in my CLA 45
Loading...
Old 08-01-2014, 01:03 PM
  #43
eason's Avatar
W212 E63
Do you have a tune as well? I went to the dealer one for "Pre Safe Function Limited" and they said dealer said they updated the software for me. My car seems to work great without any tune box, but have Pre-Safe issue once every few days with a tune.
Old 08-01-2014, 05:41 PM
  #44
kuba.95's Avatar
No I don't have the tune sadly. Just wanted to let ya know about my experiences since I experienced the same issues of having the pre safe functions limited,loss of acceleration, and everything going back to normal after restarting the car. (This issue didn't happen constantly. It occurred once per day or once every couple of days)
Old 08-01-2014, 06:47 PM
  #45
eason's Avatar
W212 E63
Did you dealer found out the problem? From what I read, it seems like the gas pedal connector is having issues.
Old 08-01-2014, 07:23 PM
  #46
kuba.95's Avatar
Ya I got it fixed after a full month of not having my car. Here was the conclusion "So here's basically what info I got from the dealership. The Error codes were C015100, and C015000 in ESP control unit.and various other fault codes related to ESP not communicating in other control unit. ESP control unit found ok. Traction system Hydraulic Unit needs replacement. ESP Electro-Hydraulic Unit replaced. ABS Pump replaced also.". Theres a whole thread on the mercedescla forum about the issue called "Having issues with my CLA 45"
Quick Reply: CLA45 AMG Tuning Special Offer - Rebellion Automotive
