Brake service
Brake service
Now that most owners had some time to use their cars, had anyone done a brake service yet? As the cars are new information on 45s are hard to come by,
1) are they labor intensive and costly?
2) ive read that they are similar to the slk pads
Maybe PM or call Rebellion. They've got pad kits they sell, also rotors, and calipers. They should be able to answer any questions about the job.
Former Vendor of MBWorld
1 Post
E63 AMG
Hi !
The brakes them self are relatively easy to do. Including preparation you should be able to do a front set in an hour or just over.
The rear set is similar however you wind back the calipers using the Cars computer accessed through the dash.
If you want a how to guide just shout and I will get one together![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
The biggest complaint from customers is the lifespan of the stock items, they seem to wear down really quick.
So if you are changing you may want to consider the 2 links below:
http://store.rebellionautomotive.co....brake-upgrade/
Both are available in normal or saw styles.
If you require OEM discs and pads we can do that too
Hi !
If you require OEM discs and pads we can do that too![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Im not used to AMG cars, had M cars in the past but maintenance cost were not so bad, and im not afraid to work on my own cars.
So AMG OEMs will tend to be expensive (comparted to a cla250) because
1) tend to wear down faster
2) overprice cause its a AMG part
any info would be great
will deff look at rebellion when the time comes
1 Post
E63 AMG
Hi,
The GLA is similar to the CLA so no difference in work time.
The parts are not massively expensive compared to the bigger AMGs. In the UK front pads and discs will be around 400gbp in parts ($600 approx) and you can change them yourself.
The rears are more expensive for some bizarre reason .. up to 700 GBP for Pads and Discs ($1100 Approx)
Wear rate is relative to how you drive.. some customers see 6000 Miles to a set and some see 20000 Miles.
Hope that helps.
Hope that helps.
