AMS 45AMG AMG CARBON FIBER COLD AIR INLET DUCT & AIR BOX LID
Its here ! What you have all been waiting for, a great upgrade with amazing looks !
Smooth Design And Unobstructed Airflow
In an effort of cost savings your 2.0L M133 turbocharged engine comes equipped with a plastic air duct which is corrugated on the inside disrupting flow. To make matters worse it also features a big support "pillar" in the middle of the airflow path to keep the flimsy plastic from collapsing which hinders power output. With the Alpha Carbon Fiber Cold Air Inlet Duct, we eliminated these restrictions supplying your hungry engine with all the cool air it needs!
Cool Air For Your Hungry Turbocharged Engine
Often aftermarket intake systems feature an open air filter element in the engine bay which draws in hot air which actually reduces horsepower. While this might net you some power on the dyno with your hood open to outside air, when you drive down the road performance is hindered by hot air from the engine bay. By taking full advantage of the cool outside air provided by a sealed air box you reap the benefit of maximum power as you fly through the gears of your Speedshift DCT 7-speed transmission.
Easy, Non-Invasive Installation
The Alpha 45 AMG Carbon Fiber Cold Air Inlet Duct & Air Box Lid requires no cutting or permanent modifications to your car.
The Difference Is in the Details
We took the time to match the carbon fiber weave pattern and finish to match your 45 AMG engine cover. In addition the Alpha logo matches in color to the AMG logo and trim found under the hood giving you a super clean look that will be sure to impress your friends!
Exclusive Benefits
Replaces factory ducting for cool air charge and maximum power
Reduces turbo lag
Smooth transition for best airflow
No computer tuning needed
Installs in 10-15 minutes
