AutoTalent | Renntech Ecu Upgrade + Suspension + Exhaust For Mercedes-benz CLA45 AMG
SPONSOR
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1024x153/e3h3wk5_1abcfc2abb0ad1bcfe01742da6c811693ce01e2b_7f416b71423a35e1f25fcd5108130cecf2e0a5cd_c07c2519b7319a7502a5ff07720821f06fbbc6f2_4673d896887764_035c15273a3c367476d6f58cf3f009beff60fbf0.png)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/1024x148/7vvm3jc_2a487a29958e257154f24ea3d382cdf0339a4083_35e1b34539289a661bbc69a4611261372dd082c8_fd90fc8225e22a7ad7bb53f7046a767bde8429e2_33f3f465695718_01c54249283c3ca69a207b346b6fabe5d11e3f35.png)
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
Click HERE to order Performance Ecu+!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Stock Performance
355 Hp @ 6,000rpm; 332 Lb-ft @ 2,250-5,000rpm
Modified Performance
428 Hp @ 6,150rpm; 417 Lb-ft @ 4,050rpm
351 Whp @ 6,150rpm; 342 Wtq @ 4,050rpm
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/ecu_tuv_m157_m278_0730acfe8cee3965573141d8c5ba6e594b143943.jpg)
Renntech Performance Stage 1 Turbo Upgrade
Click HERE to order Stage 1 Turbo Upgrade!
The Renntech Tuning Module Allows the User to Change the Performance Level and Gives the Ability to Set Different Performance Levels Running Both Higher or Lower Boost Compared to Delivered Settings. This Gives You Power on Demand or Economy When You Want With Smooth Torque Delivery and Performance Throughout the Entire Powerband. This Also Allows the User to Compensate for Fuel Quality and Places of Extreme Climate or to Adjust for Higher Octane Fuels and the Added Performance of Racing Blends. The Lightweight Forged Billet Wheel Features a Dramatically Larger Than Stock Impeller (Inlet Side) and an Increase in the Turbine Trim (Exhaust Side). This Combination of High Quality, Lightweight Components Coupled With Less Rolling Resistance Compensates for Turbo Lag Despite Being a Functionally Larger Turbo. Our Turbo Upgrade Uses a Modified Bearing and a Stronger Shaft, to Remedy the Factory's Weaknesses. The End Result is Nothing Short of Spectacular With the Renntech Turbo Package Making Up to an Incredible 460 Hp and 415 Tq at the Crank. More Power Isn’t the Only Performance Benefit as Our Turbo Spools Quicker, Offer a More Responsive Throttle and Immediate Power Delivery Thanks to a Reduction in Exhaust Back Pressure, Rolling Resistance, Higher Rpm's and a Lighter Rotating Mass. In Addition, Our Turbo Upgrade Kit Includes the Renntech Ecu Upgrade and High-performance Air Filter. The Turbo Upgrade Has Been Developed in Partnership With Renntech Gmbh, Facility in Germany, and Was Tested and Perfected on the Nürbugring. All Parts Are Tested in-house as Well to Ensure Years of 100% Trouble-free and Leak Proof Operation.
Features
The Renntech Stage I Turbo Upgrade Comes With an Ecu Upgrade and Performance Air Filter
Entire Cartridge is Fine Balanced as an Assembly
Modified Bearing and Strong Shaft
Less Rolling Resistance Offers Quicker Spooling
Virtually No Lag With Impressive Throttle Response
Up to 460 Hp and 415 Tq @ Crank
Stock Performance
460 Hp @ 6,050rpm; 464 Lb-ft @ 4,100rpm
377 Whp @ 6,050rpm; 380 Wtq @ 4,100rpm
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_m177_m178_turbo_stage_i_001_96b0e7487c85192d622140c0d5ecf8bed6f76c96.jpg)
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_m177_m178_turbo_stage_i_002_e24c5f74eb2fe246cb8a76761535abe71f1ef2f4.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_m177_m178_turbo_stage_i_003_1__4a2627565407d637f5d1b815c1a6e77506e6e1b9.jpg)
Renntech Exhaust Valve Module
Click HERE to order Exhaust Valve Module!
Renntech Plug & Play Evm Exhaust Valve Module Allows You to Open the Exhaust Flaps of Your Car 100% at All Times by Pressing Button 1 on the Remote Control. If You Wish to Go Back to Factory Settings Simnply Press Button 2. This Gives You Complete Control Over the Exhaust Sound and Rumble of Your Car at Any Time Regardless of Speed, Rpm or Driving Mode. The Renntech Exhaust Valve Module is Made in Germany. If Your Car is Equipped With Factory Exhaust Flaps, With or Without a Center Console Button to Open or Close Them, Factory Settings Do Not Allow the Flaps to Fully Open Unless Certain Speed and/or Rpm Have Been Reached. For Example, While Cruising the Exhaust Flaps Will Never Fully Open.
Features
Activation Completely Independent Regardless of Drive Mode
Override Your Cars Factory Exhaust Flap Setting With the Push of a Button
Evm Does Not Engage With Can-bus
No Interference With Any Control Units.
Software Updates Do Not Interfere With the Functionality of the Evm Exhaust Valve Module.
Plug and Play With Original Plugs
No Cutting Wires, No Damage to Factory Cables, Fully Reversible
1 X Exhaust Valve Module
2 X Remote Controls (Button 1 Fully Open, Button 2 Back to Factory)
Wiring Harness (Model Specific)
Installation Manual
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_002_copy_21be6363da842e5e8f690938090fa0c6a3c6dfe2.jpg)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_003_a819af57b5a1005b9888add624e88e1e771f6b7c.jpg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_efm_exhaust_flap_module_001_copy_152b5530151bba2f23024d54f5c7a6cd83631432.jpg)
Renntech Suspension Lower Control Arm
Click HERE to order Lower Control Arm!
The Renntech Lower Control Arm Gives More Camber Adjustment Abilities, in Order to Improve Your Track Setup/alignment. Renntech Modifies the Oem Aluminum Lower Control Arms to Allow for Camber Adjustment on Lowered Cars and Cars With Performance Setup. They Can Bring Lowered Vehicle Within Factory Alignment Specifications to Reduce Tire Wear. The Renntech Lower Control Arm Give the Best Improvement in Combination With the Renntech Toe Link Kit. The Renntech Lower Control Arm is Custom Made for the Mercedes-benz. Control Arms Connect the Vehicle’s Suspension to the Wheels With Ball Joints and to the Frame With Bushings. Car Control Arms, Also Known as a-arms, Support Each Wheel and Contribute to the Smooth Ride You’ve Come to Expect. Control Arms, Ball Joints or Bushings Can Wear Out Over Time and Require Replacement. We Carry Control Arms From Trusted Brands Like Renntech That Offer Improved Performance and Long-lasting Reliability.
Features
Give the Best Improvement to the Car
Provide a Smooth Ride
To Reduce Tire Wear
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/25_8be4b02a_1087_4cc9_9fed_4c568005c258_800x_f02ec0bc9cf5b1839772f9f401c51e20944fb52e.jpg)
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/24_e34a41a7_d777_4ba5_98d9_67251a985a02_800x_15ef2e389d3418d6c5290c63fb343e3fea1eb22f.jpg)
Renntech Suspension Toe Link Kit
Click HERE to order Toe Link Kit!
The RennTech Toe Link Kit gives more toe adjustment abilities, in order to improve your track setup/alignment. Toe Link Kit is machined out of 6061-T6 Aluminium and anodized in red. It allows on-car adjustment. They can bring lowered vehicle within factory alignment specifications to reduce tire wear. Toe Link Kit give the best improvement in combination with the RennTech Lower Control Arm. The RennTech Toe Link Kit is custom made for the Mercedes-Benz. Adding a toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. When used with RennTech adjustable camber bushings, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort. The RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics.
Features
Improved vehicle handling characteristics
Gives more camber adjustment abilities
Give the best improvement to the Car
Improve your track setup/alignment
Maintains stability at high speed
Improved performance
Long-lasting reliability
To reduce tire wear
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/32_c3410f81_3032_4005_9e62_a6d5b124837f_2000x_fac217945f361cca6970c06f5730600a4b119a58.jpg)
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/31_f06b2e45_cbb2_4404_a68e_094052d540b6_2000x_57ffdc15d7820e3df585876c45b4477c498224a3.jpg)
Renntech Suspension Carbon Fiber Front Strut Brace
Click HERE to order Carbon Fiber Front Strut Brace!
The Renntech Carbon Fiber Front Strut Tower Brace Provides Sharper Handling by Reducing Flex Under Harder Cornering Conditions and Helps to Maintain the Structural Integrity of the Towers Over the Life of the Vehicle. Also the Renntech Front Strut Brace Stabilizer Improves Your Vehicles Responsiveness and High Speed Cornering Capabilities. Especially in Combination With Our Turbo Upgrade, This Feature Improves the Handling of Your Vehicle. The Construction Features Include Reinforced Eight Point Mounting Brackets Made Out of Aluminum. The Customized Crossbar is Made Out of High-performance Carbon Fiber to Minimize Flexing Between the Vehicles Strut Towers. Titanium Bolts Are Used to Mount the Strut Brace to the Top of the Strut Towers.
Features
Improves Vehicles Responsiveness
High Quality Carbon Fiber Material
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/36_eabc9747_7adb_4c8c_b597_9c941a4caae6_2000x_2ad0b50c3a6644c7a8d90ceded835fef9d1f6f47.jpg)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/37_2000x_d92cd8244ad8596f072ed9890854ca1bddd07318.jpg)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/38_2000x_6337e556bf54547eb8237ad8f5919f9ce4a79fbc.jpg)
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Improves vehicles responsiveness
Reduce fade compared to stock
High-performance brake pads
High quality material used
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_brake_pkg_1_f1a0dd45393dd28c1c994f1626613a3615c2f1e4.jpg)
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
