Arma Speed Benz CLA250/A250 Carbon Air Intake
- stage 1 Non-Variable Carbon Air Intake
- stage 2 Variable Carbon Air Intake
-What it mean variable? Arma had brought air filter to the next level and better function than before.
Variable filter is Germany patented and world No. One design. The filter includes variable valve and made by stainless.
When the car is at lower rpm, the valve is close. It resolves tuned filter losing lower torque problem because the air flow will not get into engine too much.
Variable filter is controlled by Electronic control (ECV), use remote controller setting and connect by OBD2 port.
There are three model full open, full close and auto. When the user switches to auto, it could set up by rpm so when the rpm reach to preset rpm, the valve will open
With this Arma Variable air intake, it supplements Low end Torque and reduce Turbo leg.
