CLA Coupe (C117) 2014-present
LED Help!
Old Sep 24, 2017 | 12:29 PM
Orlando34's Avatar
2017 cla 250
LED Help!
Good afternoon,
I recently purchased a used 2017 cla 250. Love the car, hated the headlight so I decided to change the bulbs to leds. After install lights worked great. About 3 days later one of the daytimes stopped working and the day time check error came on. A day later worked and out again and now won't turn on at all. My guess is the bulb cover was to close to the Led fam and allowing it to cool properly and blew the fuse. Because it is used i did not get the fuse chart/map so I don't know what fuse to replace. Has anyone else run into this problem? Does anyone know what fuse I should check (pic of fuse box with indicator would bee great)? What else would cause this? I'm not an advanced car guru at all so any help/insight would be awesome. Thanks!!
Old Sep 29, 2017 | 10:00 PM
BenzinoZ's Avatar
2018 C43 AMG. 2018 CLA45. 2017 911. 2011 BMW M3 Coupe, Comp Pack w/ Dinan Stage 3 kit, Ti exhaust
BUMP. OP has valid question there. Where is the fuse box, #1. 2. Which is correct fuse to replace for the headlights drls &/or high beams when switching out the OEM poopsauce bulbs?
