Mercedes-Benz A Service and B Service
My screen pop out with Service B is due for my 2018 Mercedes Benz CLA 250 4matic, 25,000K, They are currently asking for 650 Canadian plus tax at the Mercedes Benz dealership.
Is it worth it to take it to dealer ship for service b? are they overpriced? or should I find a local mechanic that do service? and for service b, what kind of service should it be done?
Check all lights, warning lights and horn operation
Change synthetic engine oil and filter
Top up AdBlue (if applicable)
Replace remote key battery
Check cooling system strength and adjust level if necessary
Check brake fluid level
Check brake pad thickness (front and rear)
Check brake disc thickness (front and rear)
Check wipers, washer jets and headlamp cleaning system
Inspect suspension system
Inspect Poly V belt
Visual check for leaks on major components
Check engine air filter and replace if necessary
Check seatbelts and anchor system
Check suspension components for wear or damage
Check steering components for wear or damage
Check driveline components for wear or damage
Replace Cabin Air filter
Tire Sealant - check expiration
(if applicable)
Check and correct headlamp settings
Check bodywork for corrosion
Check Active Body Control (if applicable)
Inspect tires for condition and set pressures
Rotate tires to promote even wear
(if applicable)
Clean water cowling to ensure proper drainage
Inspect Poly V belt
(if applicable)
(if applicable)
