CLA Coupe (C118) (2019-present) that is debuting as a 2020 model
Oil Change DIY?
Old Mar 21, 2021 | 09:39 AM
03basesedan's Avatar
'20 CLA250/'07 ML500/'20 F-Type
Oil Change DIY?
Does anyone have any information on tq specs for the drain plug, size for the filter socket, etc?
I am going to tackle the first oil change today @ ~7,200 miles. I can probably figure it out myself, but the tq specs for the drain plug and oil filter cover would be helpful. I wish I had access to the service manual!
Edit: Popped the hood and oil filter housing label shows it requires 25Nm which is ~18.43 ft-lbs / 221.16 in-lbs.
The filter housing also appears to require a 27mm socket for removal. I'll report back with more when I get under the car this afternoon.
Old Mar 21, 2021 | 12:34 PM
chassis's Avatar
2017 GLE350 4MATIC
eBay WIS ASRA EPC
