Is the ABS Sensor the same on both sides?
Old Sep 12, 2016 | 04:32 PM
Petter Hanssen's Avatar
2005 C220 Sedan and 2005 A150
Hello MbWorld! I just bought a W169 with a problem with ABS/ESP.
Ive read the fault codes and it came back with defect speed sensor front right.
So I found a car that was selling some spare parts, but the only sensor listed on the website was ABS Sensor front left. Is this cable gonna fit on the right side too or do I have to keep looking?
Here is the part if you have do double check; http://finndel.no/delinfo.aspx?dnr=2...&regnr=VF69931
- Petter
Old Sep 13, 2016 | 08:56 PM
The cars VIN is WDD1690311J150981.
Ive done some troubleshooting and found out that the ABS sensor is the same on both left and right.
The part number on the cable if anyone needs it is: A 169 540 04 17
Old Sep 14, 2016 | 12:39 PM
Originally Posted by Plutoe
You are partially correct,they are both the same however the correct current part number is 169 540 14 17-----deleting you part number will eliminate future screwups\misinformation!!
Maybe both part numbers are kinda the same ? This is atleast the part number on the ABS sensor I pulled from the right front. It was the same number left front too.
