AC/heat delays
Old Oct 19, 2019 | 10:40 PM
Roger8's Avatar
A220
AC/heat delays
Anyone else experience occasional delays before the AC/heat kicks in? For example, sometimes, if I turn the fan from off to something (anything)... literally nothing happens for 10-20 seconds. No air blows, no sounds from the system. Then, all at once, the fan kicks in and it works as I'd expect.
During these delays, I've tried kicking the different settings between windshield, front, feet, but it doesn't help.
Semi-related, fan speed 1 is barely noticable. I have to hold my hand against the vent to feel the slightest of hints of air. I'd compare it to other cars I've owned where some air leaks out just when driving (without air circulation on). If I switch to #2 it becomes barely noticeable. #4 is what I'd normally think of as "low" speed. 5+ are big jumps up where the fan really kicks in (like normal). Curious if anyone has seen similar behavior. I plan to mention this to the dealer next time I take the car in.
Old Oct 20, 2019 | 04:14 PM
vfxcxn0309's Avatar
GLA
for fan speed, 1-3 = nothing, 4 is smallest, and 5 is a bit too big for me, i got same as you, i think this can be adjusted on software side.
AC/heater delay, i don't have this 10-20 sec delay, usually turns on 2-3 sec. but i have noticed, when i turn off AC, the cold air stay on for sometime, feels like i got free AC for about 10 min.
by the way, my car is at dealer for turbo oil leak/blue smoke at tail pipe, at only 1900km, so bad...waiting for dealer to get back for me.
Old Nov 26, 2019 | 04:04 PM
Roger8's Avatar
A220
I finally took it in to have the dealer check if there's a problem. I also narrowed down the symptoms. What I see this:
1. Turn on the car (only happens the first time I use heat/AC after turning the car on; even if it's just a few minutes between off/on so it's not a matter of the car heating up or something)
2. Turn on the heat where the vents are set to front (not windshield or feet)
3. After about 5 seconds, air starts blowing but only for the left and right vents (not the three center vents)
4. After about 20-30 seconds, air starts blowing out all the front vents
The dealer didn't know if this is normal or so we went to another A220 and tried it. It did the same thing which makes them think this is normal. Couldn't explain why the car would do this but it wasn't something unique to mine.
This isn't a major problem so I didn't push the issue further but I still think this is weird behavior.
Old Nov 27, 2019 | 09:44 AM
vfxcxn0309's Avatar
GLA
my A250, i only notice, there is delay on vents to blow air after i turn it on, 1-3 sec, but all vent blow at the same time after i select the hot/ac on. maybe different in A220
Old Nov 27, 2019 | 09:28 PM
Deriggs007's Avatar
A220
Mine does it as well. However, the 2019 or 2020 loaner I'm in currently does the same thing (GLC300)
