Tire pressure
Question. Since it seems to start warning at 34... and I see a tire moving between 31-34 just because of outside temperature... how much air should I put in it? For example, if I only increase it to 35-36, then I wonder if it'll still drop to 34 on a cold morning. But, if I add set it to 38... that seems high. What's the proper way to do this?
Check your tire rating, I think 38 is fine. At 35-36 psi warm you could see a drop to 30-32 in colder weather. My old car used to drop up to 6 psi when the temperature went from 90 degrees to 15.
