A-Class (W168, W169) A140, A160, A160 CDI, A170 CDI, A190, A210 Evo, A180
A190 BAS/ESP problem - resolved
Old Jul 29, 2012 | 09:00 PM
tracerr's Avatar
BMW328/A190
Hi Guys, hope this helps anyone here, my Wife has a 1999 A190 which was driving 100% fine up until one day when we started getting the BAS/ESP light on the dash....after doing some research some one said nah change the brake light switch it would resolve the problem, well it did not, some more research later I decided to clean the throttle body and MAF sensor with some carburetor cleaner, it made the problem a bit better....but then struggled to start at times, sooooo after some more research I swapped the K7 and K10 relay switches around which is for the fuel pump/rear defroster ( I didn't have a spare relay for the fuel pump one) and guess what...it worked....here everything I did myself
Change brake sensor
Reset error on dash
Checked battery
Checked speed sensors on wheels/checked Tyre pressures
Cleaned throttle body
cleaned MAF sensor
Cleaned air filter
swapped relays around
One happy Wife now
