A-Class (W168, W169) A140, A160, A160 CDI, A170 CDI, A190, A210 Evo, A180
Can only read ECM and TCM codes
Old Jun 25, 2020 | 09:25 PM
Wlpend's Avatar
CLK200K A209
CLK200K, A209, 2005, recently purchased, bought a MB V2.0 scanner and connected it to car but it only reads ECM and TCM modules, the other modules come up with a connection error. There was one historic code in ECM, a P202B-008 code. The only problem I have with the car is the Parktronic system is not working, shows red on the parking sensors display and I was hoping the scanner would help me solve problem but can’t connect. Any help in why it is not connecting would be appreciated.
Parktronic system now working.
Old Jun 26, 2020 | 07:38 AM
speedlimit's Avatar
Administrator Emeritus
Hi and welcome!
Moving your post to the forum, I hope, with the best chance to help you. Good luck!
Bob
Old Jul 3, 2020 | 01:05 AM
Wlpend's Avatar
CLK200K A209
I have today scanned the car with another scanner and same issue, can only read engine and transmission modules and came up with this error, P202B-008, CAN data from control module EIS, CAN signal interruption Drive authorization.
so the issue is with the car and not the scanner. Everything is working ok so I believe that the CAN is communicating ok, had a problem with the Parking sensors not working and found loom unplugged in boot, reconnected it and they are all working fine. I have also had an error code P2029-02 which I understand could be associated with a faulty air temperature sensor.
Old Apr 18, 2022 | 01:19 AM
Housniab's Avatar
C280 4 matic 2007
HEY Wlpend did you solve this problem because i have same problem i tested the can bus from the splicers its signal is good but i cant get good signal from the OBD connector but my car runs good with no codes my only problem is that the OBD2 scanner reads only ECM and TCM and i did read other modules with same scanner before
