W168 1.7 CDI Shutting down
W168 1.7 CDI
Hello everyone , im new on this forum.
I bought W168 1.7 CDI last week , but now i have big problems.
Last week mechanic shop changed oil & filter , fuel filter & air filter.
The problem is that the car turns off by itself, there are no rules at what speed you go, it turns off.
I hooked it up to Delphi diagnostics and it reported an error P1187.
the regulator was replaced with a used one, as well as the pressure sensor on the fuel line, but the problem remained.
I start the car, sometimes I drive 20 kilometers and everything is fine, but today it happened that it turned off 20 times in those 20 kilometers. The car shuts off, I put the ignition back on, it burned a little longer, but after 5 seconds the car starts and drives on until it shuts off.
the masters looked at the toppings on the nozzles, all 4 filled the test tubes in the same or similar way
tomorrow I have to replace the crankshaft and cam sensor.
Does anybody know what to do?
