NTG 4.5 USB-AUX enable issues
Old Aug 3, 2020 | 03:10 AM
James Chung's Avatar
A-Class W176 A180
Hey guys, I am having a hard time finding usb-aux enabling function.
I believe my system is NTG 4.5, and trying to add android unit which requires usb-aux function.
I searched online how to enable it, but my engineering mode looks different from others (maybe it is not ntg 4.5)
Anyone know the answer where to find usb-aux function or tried install android similar to my system?
Old Sep 23, 2020 | 01:09 PM
Murtas4u's Avatar
GLA 200
Hi James. I have the same problema with the engineering menu. Did you solve your problem and unlock AUX? Thank you
Old Oct 29, 2020 | 01:51 PM
A. Riso's Avatar
A Class 180 CDI
Hello guys, I have the same problem the radio is an NTG 4.5 (1CD) and the Engineering menu is the same.
has anyone managed?
Old Jun 22, 2021 | 06:04 PM
javivialacant's Avatar
GLA
Hello, I have the same problem, the radio is an NTG 4.5 with AUDIO 20 and the Engineering menu is the same. Has anyone managed to activate the AUX?
Old Oct 10, 2021 | 04:11 PM
Bigboots's Avatar
a200 night edition
I just installed a 10.25 screen into mine and there is a setting in the system menu of the android to activate it.
Hope this is of some help..
Old Dec 5, 2021 | 08:54 AM
JoshPope08's Avatar
mercedes a class A180
hi buddy, was this on a 2015 A180 W176? Im looking to fit my screen in the next week or so. I also have ntg 4.5 and no way of activating aux. Thanks
Old Jul 2, 2023 | 08:34 AM
dave_jee's Avatar
a220 W176
Hi,
Did anyone ever solve this ?
I am trying to install an IMI unit and getting the same issue. Can't find AUX option
CHeers
Old Feb 15, 2024 | 08:09 AM
amex1's Avatar
GLK
Hello.
I've come across the same problem with aux activation. Has anyone found a solution? Thank you
Old Feb 15, 2024 | 08:13 AM
dave_jee's Avatar
a220 W176
Originally Posted by amex1
Hello.
My head unit had the option to activate Aux in the system menus. Which unit do you have?
Old Feb 15, 2024 | 08:23 AM
amex1's Avatar
GLK
Hello.
I've tried that... but my menu doesn't have that option
It has this view:
Old Feb 15, 2024 | 08:24 AM
dave_jee's Avatar
a220 W176
Hello.
It has this view:
Which new head unit did you get?
Old Feb 15, 2024 | 08:52 AM
amex1's Avatar
GLK
I installed an "MMI" Android/carplay module. Everything works fine except the sound, which is supposedly because I don't have AUX active.
The hidden menu on my unit is similar to the one in this video:
Old Feb 15, 2024 | 07:44 PM
Darkecudoua's Avatar
E Class Coupe C207
Has anyone figured out what's with this different engineering mode?
Old Dec 11, 2024 | 04:38 PM
Dobbin1964's Avatar
Did you ever find an answer to this?
have the same issue and nobody seems to be able to answer this question?
Old Dec 11, 2024 | 05:30 PM
trigital's Avatar
W213 All-terrain
HU 4.5 could be Radio Audio 20 ( Head Unit A-Entry) or Comand ( Head Unit High) - the one with HDD, internal Navi, Video, etc.
The Comand model, has Audio AUX ready to be enabled for sure. The Audio 20 model, may not.
Old Dec 15, 2024 | 01:26 PM
Tetyas's Avatar
I'm having the same issue. And i'm thinking about using an obd AUX activator.
Anyone gave it a try?
