A class - Gearbox adaptation 287c00 / P287c00 after gearbox oil level check
Old Jan 1, 2024 | 01:22 PM
aszz111am's Avatar
A class
Hi all,
I have an issue with an A200D. Details below...
A-Class A200D 2016 W176
After clicking Continue on the Transmission oil level check, the dashboard immediately pinged a fault message.
Without changing gear, consult workshop.
(Xentry > Diagnostics > Y3/14n4 Electronic transmission control .. > Actuations > Oil Level check > )
The fault code is: 287c00 / P287c00 Adaptation was not completed successfully.
First of all, I was not intending to do an adaptation - Just a transmission oil level check.
Why would this cause a fault? Gears can not be selected now and engine is in limp mode.
Has anyone managed to resolve this issue? Looks like checking the oil level (electronically) causes a huge issue and you can't do an adaptation after.
A dangerous option in Xentry / Autel, if it breaks the car.
Old Feb 16, 2024 | 03:18 PM
Tfty123's Avatar
A180
Hi ! Did you ever manage to sort this I have exactly the same scenario/ problem
Old Feb 18, 2024 | 03:19 PM
aszz111am's Avatar
A class
I actually did manage to complete an Adaptation, which got the gears back.
How did performing an adaptation work for you?
https://www.linkedin.com/posts/azim-...89819904-fdb2?
See screenshots in the above link for adaptation instructions.
