W176 Big Brake Kit
Old Feb 7, 2026 | 04:06 AM
VickoGricko's Avatar
W176 Big Brake Kit
Hello everyone, thank you for having me here. I am new here and I have a few questions. Namely, it's a w176 a200d 4matic amg line pre facelift. The rims are JR28 19×8.5 et 40. I want to install a "Big brake kit". Due to the look of the rim, since the inner drum is narrower than the outer one because it has a scale / tooth, i'm interested in what options are realistic for me. I surfed the internet a bit and came across an option with 18z calipers and 375×36mm discs. Honestly, i'm afraid that it will get stuck in the inner edge of the rim that i told you about. The most realistic option seems to me to buy the OEM calipers from the w176 A45AMG (which i heard are plug and play compatible with my car) and install them on my car in combination with a 350mm disc. Every advice is welcome. The spacers are unfortunately out of the question because the rims are perfectly aligned with the car and fenders. Thank you all and I hope for a joint solution to this situation.Also, when that is done, the car will need to be lowered, and in my opinion the eibach pro kit for 4matic which lowers 330mm will lower my car by about 150mm because I already have the amg line equipment package which is lower than the rest of the equipment. Car will need a few cm of lowering to close the gap between the tire and the fender... especially in the backCoilovera are not in the budget so I guess that does not work for me... Do you have any suggestions what's the best way to lower the car without losing driving characteristics.Thank you all in advance and stay well.
