Am I the only with so many problems with my A250 ?
I bought a 2019 A250 2 years ago and since then, I go to the dealer every few months or so. So I was wondering if I am the only one with that many problems with my A250.
List of problems I have or had :
- A/C Controler unit problem, they changed it twice and the problem is back again. It's 15 degres C outside, maybe 18-20 inside the car, my temp is at 22 and the A/C is shooting cold air. I must put the temp to 24 if I don't want to freeze
- Airbag problem, passenger side, they had to tighten some cable
- I deactivated the autofolding mirrors but the reactivated themselves over time. They had to changed the doors modules.
- My hatch wouldn't close one day, they had to change the hatch lock
- I have the keyless option and sometime when I put my hand on the door handle to lock it, it doesn't lock.
- I had a problem with the engine, went they checked it, they found that I have an air leak within one cylinder and they must change the engine head.
- I have a check engine light and it's the second time I have this, the first time, they change an air sensor or something like that.
- A few days ago, I was going somewhere with the navigation system and suddently, ma car was wayyy out of where I was
As you can see, that's a lot of problems, some are just annoying, some are serious and today, I began thinking of changing my car for obvious reasons.
So, I'd like to hear you guys to see if you have problems with your A250.
Thanks,
Dominic
