A-Class (W177) (V177) 2018 to present
A220 Projector / Puddle Light Blinking
Old Aug 10, 2022 | 08:48 PM
dwhite's Avatar
2020 A220 4matic
I have a 2020 A220 and I just installed the OEM projector light. If I install both, they are blinking and won't stay lit. Actually, the driver side will blink 3-4 times and then it will stay lit but the passenger side will not stop blinking. I found a workaround by only installing the projector light on the driver side. So it means the driver side has the stock lights. I bought part number A 247 820 87 02 as seen on the pic. I did call the MB parts department and gave them my VIN number and they verified it is part number A 247 820 87 02. What I noticed though is the part number on the actual item is different (A 247 906 33 03). I want to know for the guys who have the same model car and with the projector light if they can check the part number. Thanks in advance.
Old Aug 15, 2022 | 01:08 PM
dwhite's Avatar
2020 A220 4matic
I did more research and found a German parts retailer that shows the projector light is only compatible to cars with code U62 (Light and Sight package). Unfortunately my car doesn't have that so I asked MB service department if they can enable code U62. They said they could for $198! What's weird is that I checked what's included in the Light and Sight Package and I have everything in my car:
https://www.la.mercedes-benz.com/en/...ight-and-sight
BTW.. I checked 2 other vendors and the part number on the actual item is really different from what's in the box label.
Old Apr 24, 2023 | 06:35 AM
MaxMBA's Avatar
A200d
I must say that I have the same issue and I have code U62 activated on my car as standard. So I check the catalogue and these lights are compatible and specific for the car, however still blinking but only on the passenger side.
